split cv boots
Old Aug 29, 2018 | 06:04 PM
cult colt's Avatar
Default split cv boots
I have a '81 240 D . The cv boots are torn. I have new axles but I need to drive the car for a little while before I can install them. They are barely starting to make noise and there is a very small amount of play in the axles if you jack it up and move them with your hand. I want to put on the kind of boots that have a seam on the side so you don't have to remove the axle, preferably the kind with a bolted rather than glued seam.I had good luck with this type of boot on an old VW van. Can anyone tell me where to find ones that are a specific fit for this vehicle? There are "universal" ones. Does anyone know if any of these will fit. I intend this to be a temporary fix that would stop the joint from becoming contaminated and to replace the grease. If I can find the correct boots, what would be the best way to clean the joints before installing the boots and grease? Should I drench it with parts cleaner? Thanks for your good advice.
Old Aug 29, 2018 | 06:32 PM
PelicanParts.com's Avatar
Hello - I was able to find some specific to your 240D, take a look at the link below and please let us know if you have any questions.
https://www.pelicanparts.com/More_In...SABEgJ8R_D_BwE
https://www.pelicanparts.com/More_In...iABEgLzkfD_BwE
cult colt
Mar 30, 2019 06:38 PM
dreya300
Sep 3, 2008 07:11 PM
timberfield
Aug 27, 2008 12:21 AM
cambo
Dec 8, 2007 12:00 PM
AJ
Sep 21, 2005 02:32 PM
