sensor location
Old May 15, 2006 | 03:43 PM
Valerio's Avatar
Default sensor location
Hello,
Before I anyone thinks I'm an idoit, the trunk and the luggage cover are closed.
I have a 99 clk320
and the softtop just stopped working, the dealer is 2 hours away, so I always try to fix the problem myself before taking the trip.
Apparantly the top has a number of sensors that must sequentailly check as the top goes through the processes of rasing/lowering
can anyone show me the location/schematic and some testing tchnics on how to diagnose which sensor is bad
the switch blinks slowly.
also, would low fluid be the problem, and where is the resevoire?
My vin is wdblk65g8xt017894 in case this helps.
Old May 15, 2006 | 04:48 PM
Valerio's Avatar
Default RE: sensor location
also, this started happening after i played with the roll bar.
Old May 15, 2006 | 06:08 PM
Valerio's Avatar
it definately has something to do with the roll bar, after trouble shooting every sensor I can find. It magically started working after I played with the roll bar switch. The roll bar goes up but will not go down. if you press and hold the roll bar up, after a few seconds the tonnau cover pulls down for a split second, I think the car must be sensing that the roll bar is up and that is why it won't move the roof. Has anyone had any problems with this and what can be done to remedy this.
Old May 16, 2006 | 12:08 AM
sleepwalker's Avatar
roof won't work if rollbar is deployed.
bring down the rollbar first.
Old May 16, 2006 | 10:32 AM
Valerio's Avatar
I know that the roof will not work with the roll bar up, but it will not go down.
If I press and hold the rollbar button up, the tonneau cover jerks up violently.
also, where is the reseviore? and the screw inside the trunk should it be tight to the left or tight to the right.
Old May 16, 2006 | 11:54 AM
are you talking about the roof or the rollbar?
if you want to release the roof manually, to the left to open the pressure.
the rollbar is spring loaded. you need to press the catch in order to take it down.
Old May 16, 2006 | 02:07 PM
Valerio's Avatar
thank you in advance for all the help anyone has given me,
roll bar is stuck up, pump is not working at all any more.
how do I manually lower the roll bar.
Old Jul 14, 2006 | 03:54 AM
have you lower it down already?
naseeb
Oct 24, 2011 08:22 AM
dpwaters
Sep 8, 2007 05:51 PM
techteam
Sep 27, 2005 12:43 AM
rich121
Sep 10, 2005 06:14 PM
s420sanjose
Dec 10, 2004 12:48 PM
