s320 1994, where and how-carbon clogging tube,,could this cquse sulfur smell..is it easy to clean,
Old Jan 6, 2006 | 02:33 AM
ftpbrebeuf's Avatar
Default s320 1994, where and how-carbon clogging tube,,could this cquse sulfur smell..is it easy to clean,
is is easy to get to, easy to clean, do you use carb. cleaner,,,how much,,can you use a paper towell?
Carbon clogging tube,,,egr valve?
Old Jan 6, 2006 | 05:00 AM
sleepwalker's Avatar
Default RE: s320 1994, where and how-carbon clogging tube,,could this cquse sulfur smell..is it easy to clea
sulfur smell is on fuel quality too.
carb cleaner is also good to soften the carbon deposits and you can clean them up with anything...depending on how thick the accumulation are.
Old Jan 7, 2006 | 12:21 PM
Lugnut's Avatar
Default RE: s320 1994, where and how-carbon clogging tube,,could this cquse sulfur smell..is it easy to clean,
The sulphur smell is probably coming from the cats. Do you smell it when you cruise for awhile then stomp the gas pedal to pass or something? If so, change brands of gas and see if that makes a difference.
Cleaning the EGR tube is never a bad idea. They do get grimey.
MAJED911
Nov 29, 2011 04:30 PM
cult colt
Aug 24, 2011 12:29 PM
EG3
Aug 23, 2007 06:22 AM
tprior
Oct 5, 2005 08:39 PM
