PSE pump location 2001 S500
snanceki is correct. Be careful when removing the pull out tabs holding the trunk, carpeted trim panels, they break easy or get lost. Pump is wedged next to the gas tank on mine, am sure same for you. Pump will pull out withthe hoses connected, barely, just be careful. Pump total fail is rare, usually needs cleaning inside the assembly and the pump head and the inside assembly hoses and the check the external hoses' connections and hose quality . Good Luck
