no start when warm
Old 01-29-2004 | 06:23 PM
marinos's Avatar
Default no start when warm
HELLO,I OWN A 450 SEL 1980,AND I HAVE THE FOLLOWING PROBLEM.</P>
THE CAR WILL START FINE WHEN ENGINE IS COLD,BUT WONT WHEN ENGINE IS WARM,IF I STOP THE ENGINE AND RESTART RIGHT AWAY IS FINE,IF I WAIT FEW MINUTE IT WILL NOT START OR IT WILL WITH A LOT OF CRANKING.</P>
I HAVE BEEN TOLD THAT IS A PROBLEM RELATED WITH THE FUEL DELIVERY SYSTEM?????????</P>
Old 02-03-2004 | 11:20 PM
Rodger's Avatar
I had a 85 sel that had this problem. There is a ck valve in the fuel line near the tank. If this goes bad when you shut the engine off you losse pressure witch causes a bleedoff of the injectors now you have a flooded engine. most small shops can do this test for you. good luck
jbellia
07-16-2008 09:39 AM
Robinbird
09-09-2007 03:32 AM
pathtowealth
06-10-2007 04:26 PM
ml320ken
11-06-2006 09:59 AM
jagclassic2002
05-18-2006 12:18 AM
