New to Mercedes/need advice
Old Aug 10, 2007 | 01:11 PM
  #11
nn187's Avatar
Default RE: New to Mercedes/need advice
So any suggestions on what I should do?
Old Aug 15, 2007 | 12:47 PM
  #12
MBTECHINFO's Avatar
You want to order the egr valve along with the tubing, flare fitting, and pipe. 50% the time, the egr tube will break/be stuck to the valve itself and will need to be cut off. The good news is that the egr valve has a new switchover solenoid with it. check the vacuum line going to the egr switchover before buying an egr valve though. Pretty simple to replace, common failure with age. The 220 chasis "s" class had a few issues, especially with the launch units. Common thrust arm and ball joint failures. The control arm bushings were also breaking occasionally and cut into the subframe, therfore requiring entire subframe. Many problems with front struts leaking at the top capsules and airmatic pump failures. A nice car to drive but you can sink alot of money into it really quick! If you want a vehicle to work on yourself, this is not the right choice but i'd take it over a 7 series any day.
fjc335i
Jul 14, 2008 12:41 PM
papidos
Jul 16, 2007 10:47 AM
smokey148
Nov 14, 2006 06:21 PM
MrsDINK
May 17, 2006 09:15 PM
E280
Jul 26, 2003 09:02 PM
