Need quick response: Liqui Moly 229.3 vs 229.5?
Old Aug 15, 2017 | 10:14 AM
flycaster's Avatar
Default Need quick response: Liqui Moly 229.3 vs 229.5?
It's time for my service A on my 2017 C300 coupe, but I understand that I don't need to pay MB $350 for an oil/filter change. Normally, I'd DIY it, but getting a little long in the tooth and lazy, so I'm planning on having my local foreign car mechanic do it. But I have a problem with the oil he wants to use and would appreciate a quick reply to my question (have an apptment on Thursday morning):
He wants to use Liqui Moly Premium Synthetic 5w-40 (http://www.ebay.com/itm/5-Liter-Liqu...-/172750137817). The Liqui Moly and 5W-40 part is fine with me, but reading on the lower part of the label, one sees "...MB 229.3..." It is my understanding that the approved number should be "229.5." So before I let him change the oil, I want to make sure that MB won't be able to claim that I used the wrong oil when I return the lease in two years.
Old Aug 16, 2017 | 01:54 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Take a look below at some info that I was able to find for you. Hope this helps!
"Vehicles with the Mercedes Maintenance System starting with MY2005 can use 229.5 or 229.51 oils.
Vehicles with the Flexible Service System FSS from MY1998-2004 can use 229.5, 229.51 or 229.3 oils.
229.5 and 229.51 engine oils must be used with fleece oil filter when used with the Mercedes Maintenance System (MY2005+) in M112, M113, M272 and M273 engines. With FSS paper filters are fine.
MB sheet 229.1 approved oils
for passenger cars with gas and diesel engines, used to be minimum spec for latest (98+) engines, high detergent, dispersant spec suitable for normal drain intervals. Based on ACEA A3, B3. Note 229.1 oils are not recommended for MB's latest (2002+) 4 valve gas M271, M275, M285 and diesel OM646, OM647, OM648 engines.
MB sheet 229.3 approved oils
for passenger cars with gas and diesel engines with extended drain interval indicator FSS up to 20,000 km, or 40,000 km - 25,000 mi, current minimum spec for 1998+ MB engines, min. 1.0% fuel saving compared to 229.1, based on ACEA A3 B4. For gas engine of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
MB sheet 229.31 approved oils; LA "low ash" Oils
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters, e.g. W211 E200 CDI, E220 CDI. The spec was introduced 7/2003. They are called LA "low ash" or "low SAPS" oils, low on sulfated ash, phosphorus and sulphur to limit exhaust particle filter pollution. In 2004 the ACEA introduced the new C3 spec (mid SAPS, normal viscosity) based on it. Change intervals extend to 15,000 km.
MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. ACEA A3 B4. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils.
MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3."
Old Sep 10, 2017 | 04:29 AM
mybenz17's Avatar
You should use the appropriate oil to assure the safety of your car or you can consult any expert auto mechanic to give you more idea about this problem.
Old Sep 15, 2017 | 11:00 AM
flycaster's Avatar
Had the oil change and used the appropriate spec'd oil (229.5,) of course, but not Moly. Bought the oil myself for about $5+/qt, indy had the right filter and charged me only $50 for the Service A. Screw MB and their $350 rip-off.
Old Feb 15, 2024 | 08:55 PM
thomaschristopher's Avatar
229.5 and 229.51 engine oils must be used with fleece oil filters when used with the Mercedes Maintenance System site (MY2005+) in M112, M113, M272, and M273 engines. With FSS paper filters are fine.
I have been doing a little reading to familiarise myself with Audi. I don't want to just be mesmerized by the good looks and great features. Someone commented that they were being charged $250 for a oil change, battery $300, fan belt $3000. Are these things normally this expensive or is this just a one off situation.
Leonel Arana
Dec 19, 2009 11:59 AM
silver fox
Jan 21, 2009 08:08 AM
gr8E270CDI
Jan 19, 2008 12:13 AM
Mr.47
Sep 8, 2007 08:09 PM
benjaro
Oct 21, 2005 01:46 PM
