Motor mounts replacement
I’m trying to replace the motor mounts on my 2011 Mercedes E350 4Matic but I can’t figure out how to remove the the metal heat shield above the mounts. I took the one bolt out but the shield will not move. Anyone with ideas can post here or email me at auerochs@hotmail.com
I don't know your car there is several YouTube videos on it I just posted these 2 but there is more.
2011 Mercedes Benz E350 engine mount replacement - YouTube
https://www.youtube.com/watch?v=07qSy_GHUyo
Whether you're replacing worn motor mounts or upgrading your entire powertrain for peak performance, every part plays a critical role. At Supertech, we specialize in high-performance valves <!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->pistons and valve train components trusted across all forms of racing—from Drag and Rally to Road Racing. Precision, durability, and performance are built into everything we make. And if your setup demands a custom solution, our team is ready to engineer the perfect fit to keep your engine running strong and stable under any conditions.
