ML320 Technical Problems
Hi All,
New member here, and I've got a couple of questions. I just bought a '98 ML320 the other day, and so far I love it, but there are a couple of quirks it has. The first is that the fuel guage does not function correctly. When I fill the tank is goes up to the 3/4 mark, occasionally drops to the 1/2 mark, then jumps up to over 3/4 but under full. It's been at just under the 1/2 tank mark for a couple of days, no movement at all. Any ideas?
Also, the previous owner managed to bugger up the signal lever. When the left signal is engaged, it doesn't disengage after making a left turn: the right signal works fine. What is involved in replacing the hardware behind the signal lever?
Thanks everyone, and I look forward to chatting on the forum!
RE: ML320 Technical Problems
sounds like the fuel level sending unit which commenly went bad on those vehicles. there is an updated fuel level sending unit u can buy however sometimesthe connections arent the same as the old one for the fuel lines. in that case u would also have to buy fuel lines and a new fuel filter. not a fun job either. its located via an access plate underneath the carpet inside the vehicle near rear of back left seat. sometimes removal of seat is nessacary. once u get to it u will see a metal plate glued down with body filler glue (white sealant around plate, or used to be white, mabey yellowish now.) once u get the plate off u will see it. not a fun job. but most likely the problem.
investoreducator
05-07-2009 08:33 PM
RuthMarx
02-15-2005 07:37 PM
