how can i save gas in a 560 sel ???
Old Jun 17, 2008 | 01:28 AM
sjs10512's Avatar
Default how can i save gas in a 560 sel ???
i need help with finding way to save gas because of right now my 88 560 sel is my daily driver and gas isnt soo good in that car...
should i go with a smaller motor or what ???
Old Jun 19, 2008 | 01:38 PM
BLUETEAM's Avatar
Default RE: how can i save gas in a 560 sel ???
PARK IT!!
THAT ENGINE IS NOT KNOWN FOR GOOD FUEL ECONOMY.
Old Jun 24, 2008 | 07:10 AM
Schnezza's Avatar
Buy an E430. I ditched my 380SEC for an 99 E430 Avantgarde and I get 700+ miles per tank compared to 300 from the SEC. Much faster car too!!
Old Jun 24, 2008 | 12:12 PM
idecelr8's Avatar
Change your oil and while doing it put in a liter of Slick 50 or something else contaning Teflon. It should give you about an 8% boost in MPG.
After 3000 miles change your oil and filter. Put in Mobil 1 and use a premium brand oil filter. This is ususally good for another 10% boost. You can also run Synthetic oil for about 15,000 miles before changing it.
Other synthetic brands would likely work as well. I just started useing Mobil 1 about 30 years ago and have just stuck with it.
Watch for leaks at your seals after this as all synthetic oils leak past the front and rear crank seal worse than conventional oils.
I did this in my VW van and a 240D and got pretty much the same results from both. I had to change the 240D oil every 6,000 miles as diesel fuel breaks down oil, even the synthetics, faster than conventional oil.
If you do try this then post your results on this board. We could all use the information you come up with.
Sam
Scuddog
Jul 2, 2008 10:23 PM
RVR
Apr 30, 2006 10:49 PM
korte4260
Apr 1, 2005 04:27 PM
bsutton101
Oct 6, 2004 05:47 PM
