Help - small mechanical problems
Old Aug 25, 2008 | 08:33 PM
matt.burden's Avatar
Default Help - small mechanical problems
I've just bought a Mercedes SLK Compressor year 2000 with 52,000 miles on the clock. There are 2 small mechanical issues. First, the low coolant warning light comes on when the engine temperature goes over 80degC - the engine is not over heating, as it never goes above 90degC, and the coolant level seems fine when I check it. Secondly, the electric roof, keeps stopping in mid operation - to fix it, i turn the engine off then on, wait a few minutes, and then it finishes the operation. any ideas? thanks
Old Aug 26, 2008 | 12:01 AM
snanceki's Avatar
Default RE: Help - small mechanical problems
Checked the fluid level?
Pump and reservoir located behind the hatch on the RHS of the trunk.
Stuart
Old Aug 29, 2008 | 07:54 AM
andry's Avatar
try to check radiator water pump.
the electric roof, sound like switch or motor problem
roofis303
Mercedes A Class
Feb 27, 2010 06:55 AM
kurnia.2
Aug 12, 2008 02:53 AM
99benzer
May 23, 2007 07:24 PM
lambert04
Jul 25, 2006 05:55 AM
CorvairTurbo
Jan 9, 2006 12:21 PM
