Heeeelp! Locked-out + no battery...
Old Nov 5, 2005 | 02:57 PM
mpatton's Avatar
Default Heeeelp! Locked-out + no battery...
Hi All,
CLK 230 (1999)
Here's my predicament.
I removed the battery to recharge it. I inadvertantly closed the trunk ('boot' in UK). I then discovered that the manual key will only go two-thirds of the way into the trunk lock (though it does lock/unlock the doors). I have sprayed all sorts of releasing oil into the aperture but to no avail.
Does anybody know of any secondary electrical points under the hood ('bonnet') where I could connect the battery in order to use the electronic key to open the trunk?
Desperate of Egham (UK)
Old Nov 5, 2005 | 03:07 PM
Kajtek1's Avatar
Default RE: Heeeelp! Locked-out + no battery...
Didn't try it, but for electrical trunk opening all it would take is jumper thru cigarette lighter, or connecting to main rail on fuse box.
Than about the key. Are you sure you are not using wallet key on the trunk?
Old Nov 5, 2005 | 05:35 PM
mpatton's Avatar
What's a 'wallet key' - All I have is the key part that slides out of the electronic key. Is there another key?
Old Nov 5, 2005 | 08:19 PM
Kajtek1's Avatar
All MB cars, that I know comes with factory 2 main keys and one wallet key, that you give to wallet, when you use the service, or to mechanic.
This key will not open trunk, or glove compartment, so you don't have to worry about cleaning it for the service.
If you have another key, try it.
Old Nov 5, 2005 | 08:26 PM
Lugnut's Avatar
He means a valet key.
Old Nov 5, 2005 | 08:29 PM
Kajtek1's Avatar
Thank Lug.
I correct my older stutement now and sey, that taxpayers money spent on your aducation are not totall vasted.
Old Nov 5, 2005 | 09:52 PM
Lugnut's Avatar
Otay. U're velcum.
Irv1000
Jan 30, 2014 05:28 PM
Quincelady
Apr 28, 2013 05:46 PM
joao_c180_1993
Nov 20, 2007 02:17 PM
idelator
Apr 1, 2007 02:13 AM
hokucnc
Apr 16, 2005 01:26 AM
