glow plug dash light flashes
Old Sep 3, 2007 | 05:50 PM
Daimler_Benz300sd's Avatar
Default glow plug dash light flashes
I have a few questions regarding my Turbo Diesel.
Sometimes when I turn the ignition on to warm the glow plugs the dash indicator flashes instead of staying solid. Also, when it does this it seems to start hard, like the plugs are not heating up. If I drive the car frequently it does it less. Is this the glow plug relay going bad?
Also...
I recently replaced, not at the same time, the Alternator and Battery. But for some reason the battery "dummy - light" is on dully at idle. You can only really see it at night and when the revs are up the light goes away. I've charged the new battery and used a tester on it. Checks out Ok. I've also checked the charging system. Is there something I'm missing?
Any ideas?
Thx,
Old Sep 3, 2007 | 07:28 PM
chassis221's Avatar
Default RE: glow plug dash light flashes
you probably do have a bad glow plug, or glow plug module, you can test your glow plugs by using an ohm meter and put one to ground and the other on the top of the glow plug( after taking off the glow plug wire) . compare to other glow plugs which ever one has great resistance is the bad plug.
71inka02
Oct 18, 2008 06:30 AM
Johnathebar
Jan 3, 2008 11:54 AM
WillCouncil
Nov 23, 2007 11:11 AM
lovedabch
Jul 12, 2007 10:29 PM
jab
Sep 10, 2006 03:04 PM
