fuse grilled when i want to turn on the starter
Old Nov 21, 2007 | 09:06 AM
kaiser78's Avatar
Default fuse grilled when i want to turn on the starter
Hi everybody,
I have a serious problem on my c 220 cdi 2002 and 150000Kms, the problem is when i want to turn on my engine after the preheating, a fuse grilled this fuse is in the a fuse box on the right of the vehicule when we are in front of the position of the fuse is 52 and the value is15 A. on the electrical sheme this fuse is for the starter.
Old Nov 21, 2007 | 10:54 PM
BlueSilver's Avatar
Default RE: fuse grilled when i want to turn on the starter
Hi kaiser78,
Immediately what comes to mind, is either a) the starter is bad; you can bench-test the starter.or b) the cables going to the starter have been pinched, chewed or rubbed through, and are somehow making electrical ground source contact with the engine block, a bracket etc.
Old Nov 23, 2007 | 06:42 AM
kaiser78's Avatar
Thanks blue silver for your answer also how can i dismount the starter and there is no mounting / dismounting instructions for that.
Old Nov 24, 2007 | 04:37 AM
BlueSilver's Avatar
I don't have the instructions. It generally involves, disconnecting the battery, diconnecting the wires from the starter, removing the mounting bolts of the starter, inspecting the cables for holes burns or abrasions, bolting the starter to workbench and testing its operation with 12 volts.
Ford1604
Jul 6, 2013 06:06 PM
Jorge Adame
Mar 7, 2012 01:09 PM
njt0001
Apr 11, 2011 01:26 PM
MA Mechanic
Mar 28, 2009 04:03 PM
elexum
Feb 24, 2008 05:51 PM
