diesel q&a
hello all iam brand new to the mercedes world and know nothing about them
it is an 84 300d diesel it runs good what is a lot of miles for these motors ?
it has power everything and i am ripping my hair out because the heater dosent workat least the buttons dont . the sun roof motor whirrs but nothing happens and the dash lights dont work the gauges do but nothing else except one other than that it is a good car a bit slow though. i am 15 and this is my first car it was free i had to work for my uncle for three weekends.
I have an 87 300D with 250000 miles, and it still runns like a champ. I regards to your heater problem, most likely your heater valve solenoin is not funtioning. Its easy to fix, and you can get them at most junk yards for a few bucks. The funtion of this part is to keep hot water from entering you heater core. If this doesnt fix the problem, you might need to replace the climate contol panel. I'm not sure how the sunroof on your particular car works, but on mine, the motor is in the trunk near the power antenna motor, and the roof opens and closes with a cable; perhaps the cable on your is disconnected or broken. None of my dash light worked when I first got the car, so I pulled it out, cleaned all the connections, and its all good now.
If you use comon sense and take your time, plus have some electrical knowedge. You can find the problems. 183000 is not a lot of miles if it has recieved good maitenence before, but if it was neglected simple such could add up. Good safe vehical and the slow part should keep you out of trouble/ Should.
87 300 D 215k
87 300 D 215k
mercedesdieselpetr
Apr 1, 2015 09:13 PM
boni_vila
May 14, 2009 04:46 PM
Dallas 300SDL
Nov 17, 2007 01:34 PM
