car won't turn off
Old Jul 3, 2006 | 02:04 AM
peaceandloveforus's Avatar
Default car won't turn off
I have a 1984 300 TDT . Yesterday I replaced both fuel filters. The car started right up and ran great but IT WILL NOT TURN OFF. Can anyone please tell me why my car won't turn off with the key???!!!!!
Old Jul 3, 2006 | 03:13 AM
Battlecat714's Avatar
Default RE: car won't turn off
so is it on as i'm typing this? the key won't budge?
Old Jul 3, 2006 | 04:38 AM
duxdevil's Avatar
I know esactly what you did: while working in the engine compartment, you musthave nudged or budged a vacuume hose, ruioning the vacuume. fortunately all you need to do to repair it is secure it again. Were you anywhere near the oil filter? all those lines around it with colored ends are vac. hoses and are very fragile to be bumbed of their nipples. all you have to do is secure it back onto the nipple. in the mean time there is a manual hand switch that says "OFF" lever in the engine that you have to push down to manualy shut the engine off. This happened to be when i got hit im my 87 190 td.
its all here are www.dieselgiant.com in the mercedes diesel maintenande section.
btw this trick with the manual shut off emergency switch IS in the owners manual under "tips and tricks" or "practical hints"
Old Jul 3, 2006 | 11:31 PM
I turn the key to off position a remove it but the car still keeps running off the battery.
Old Jul 4, 2006 | 12:12 AM
bad or dirty terminals?
Old Jul 4, 2006 | 01:13 AM
duxdevil's Avatar
DID YOU USE THE EMERGENCY SHUT OFF VALVE OR READ ANYTHING THAT I WROTE BEFORE!?!? YOU VERY CLEARLY BUMPED AN IGNITION VACUUME HOSE.
Old Jul 16, 2006 | 03:19 PM
stahlkrieger's Avatar
I am guessing its a diesel..........if so, the fuel cutoff selonoid is stuck thus not cutting off fuel supply.
Michael
jazharp
May 25, 2016 09:30 AM
redtees1
Jun 20, 2011 03:13 AM
n4hen
Aug 19, 2007 10:44 AM
fastmike99
Oct 28, 2006 04:21 PM
