broblem with Mercedes GL 420 CDI
Hello I’m from Crete Greece Dear Sirs,
My name Mavrakis Spiros, and I live in Heraklion Crete Greece. I bought a Mercedes GL 420 CDI SUV the September of 2007 from the local dealer here in Heraklion “MOTORCAR SA”. The problems start from the beginning :
My opinion of the Mercedes brand is one of the best.
I bought a car which I consider the very best in it's category but unfortunately it must be defective due to constant and repeated problems since the day I bought it.
I must say that the dealer's support is very good and immediate. Did you suggest me a solution to my car's problems.
Thanks in advance
Regards
Mavrakis Spiros
- At 21-11-07 and 2090 km, problem with the left mirror ( couldn't open while unlocking the car).Replaced by the local dealer due to warranty.
- At 10-01-08 and 6100 km, problem with the airmatic (couldn't lift the car)and the right seat of the third row of seats wouldn't open).Both replaced by the local dealer due to warranty.
- At 15-01-08 and 6300km , problem with a broken gear-wheel at the differential.differential.Replaced and repaired by the local dealer due to warranty.
- At 14-04-08 and 8500km, again problem with the airmatic.Replaced by the local dealer due to warranty.
- At 12-05-08 and 8800km, same problem with the airmatic.Replaced the air compressor by the local dealer due to warranty.
- At 08-10-08 and 12187km, replaced upper front wishbones by the local dealer due to warranty.
- At 13-10-08 and 12680km, replaced wire at the brake system by the local dealer due to warranty.
- At 08-01-09 and 15255km replaced lower front wishbones by the local dealer due to warranty, replaced front dampers both by the local dealer due to warranty.
- With 16500km , replaced front axle of the differential by the local dealer due to warranty.
- At 23-02-09 and 18750km, problem with again a broken gear-wheel at the differential. The car still remains at the dealer.
Thanks in advance
Regards
Mavrakis Spiros
JaBlonde
Aug 29, 2011 06:57 PM
bounce
May 8, 2010 10:59 AM
