240d clutch/gear grind
Old Jun 10, 2008 | 07:44 AM
sidviciousx's Avatar
Default 240d clutch/gear grind
this is my first mercedes, a 1981 240d manual shift.
its grinding in first and reverse. after some driving, there's much wobble going into first.
any quick guesses?
regards,
chuck gibson
Old Jun 10, 2008 | 03:38 PM
idcelr8's Avatar
Default RE: 240d clutch/gear grind
A bit of grinding while going into reverse is somewhat normal. Reverse is not syncronised with the rest of the gears.
The grinding while going into first can be minimized by coming to a full stop before shifting into first. In this case the problem sounds like a worn synrco.
The sloppy shifting when warm is likey a worn or loose transmission mount. This should be repaired as it is cheap and easy to do.
Sam
Alfie63
Oct 7, 2013 04:04 AM
Hayley7
Mercedes A Class
Dec 8, 2010 06:32 AM
rover1
Aug 31, 2005 06:15 AM
ZBenz
Oct 10, 2004 07:59 PM
ZBenz
Jul 5, 2004 02:38 AM
