2003 S430 check engine light
Old Aug 25, 2007 | 01:53 AM
1stbenz's Avatar
Default 2003 S430 check engine light
Just got a S430 2 weeks ago and the check engine light came on today and my car doesn't start.If I try to start it a couple times, eventually it does but what could cause this? What did I get myself into???
Chris
Old Aug 27, 2007 | 12:10 AM
snanceki's Avatar
Default RE: 2003 S430 check engine light
Get OBD (on board diagnostic) codes read and come back. ie P0170 or whatever.
Tank fuel level?
Last refuelled?
Runs OK once going?
Vehicle mileage / Service history?
Stuart
Old Aug 27, 2007 | 02:18 PM
cbowen's Avatar
Hi, I purchased a 2002 S430 several months ago. Had some small problems that were fixed. A diognastic will pick up your problem. Could be a weak battery. If the battery is beginning to run out it can cause additional problems affecting the computer.
Charlie
Old Aug 31, 2007 | 12:04 PM
Sicilian's Avatar
I'm having the same problem with my 2001 S430, when I try to start it, the engineturn like it's about to start but it won't start, better yet it sound like when a car run out gas and you're trying to start it and the check engine light comes on.Everytime it does that I have to wait about 15 minutes then it will start. twice while at a red light it died on me.
Old Sep 1, 2007 | 12:58 AM
snanceki's Avatar
So I suggest you take my advice and get the codes read. Any harage and some do it for FREE.
Then come back if necessary.
A no start WITHOUT the Check Engine Light CEL/ codes is usually the crank position sensor CPS. However you have the CEL illuminated.
Stuart.
Old Sep 5, 2007 | 01:03 AM
kotty's Avatar
Is your mercedes radiator leaking? Have you checked it already? You have to examine the pavement beneath your car after it's been parked for some time. Goodluck!
Old Sep 5, 2007 | 07:45 AM
essbenz's Avatar
you need to get it put on a decent diagnostic machine, cars with stars will be happy to help.
ring danny on 0208 444 8771
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
