2002 ML320 questions
Old Sep 3, 2008 | 11:03 PM
ronlee's Avatar
Default 2002 ML320 questions
I own 2002 ML320 andI need to knowa couple ofthings.
1. Howto reset FSS swich after the oil change?
2. Where is the fuel filter located?
3. Is there anyone has a service manual which I can buy?
Ron from Vancouver
Old Sep 4, 2008 | 08:51 AM
benztec_admin's Avatar
Banned
Default RE: 2002 ML320 questions
1.Sitting in driver seat, door closed. Turn keyto position before ignition, push in reset **** until service indicator comes up. Turn off key then quickly push and hold reset **** with other hand then again quickly turn key on back to initial position. service reminder should then reset, if not repeat process until correctly completed.
2. Behind left rear inner fender liner, between body and subframe.
3.
Old Sep 5, 2008 | 10:04 PM
ronlee's Avatar
Thank you for your advice.
Esch2k
Dec 12, 2009 06:18 PM
ronlee
Sep 5, 2008 09:59 PM
Learick
Jan 22, 2008 10:07 AM
chris_v
Jul 16, 2007 07:28 AM
jkap
Nov 16, 2005 11:56 PM
