1998 SOFT TOP WON'T LOCK
Old Sep 29, 2007 | 12:58 PM
bigman333's Avatar
Default 1998 SOFT TOP WON'T LOCK
THE SOFT TOPGOES DOWN BUT WON'T GO IN THE HOLE AND LOCK ON THE DRIVER REAR SIDE IN THE BACK. THE PASSENGER DOES GO IN THE HOLE AND LOCK. WHAT WOULD KEEP IT FROM LOCKING IN PLACE
Old Sep 29, 2007 | 01:02 PM
bigman333's Avatar
Default RE: 1998 SOFT TOP WON'T LOCK
THE SOFT TOP WILL GO DOWN BUT ON THE DRIVER'S SIDE IN THE REAR IF WON'T GO IN THE SMALL HOLE AND LOCK, THE PASSENGER SIDE DOES LOCK. WHAT WOULD CAUSE THIS AND HOW CAN I FIX IT.
THANK FOR YOU HELP
Old Sep 29, 2007 | 02:46 PM
SunGuy62's Avatar
This has obviously got you concerned...BUT COULD YOU TURN OFF THE CAPS BUTTON!
What may be happening is the catch is twisted/bent on the side that won't engage. Lift the rear bow out of the way, shine a flash light into the hole on the good side, and note the alignment of the catch. Now move to the non -working side and check the position of the catch. If out of line, it can easily be turned into the correct operating position. You may go through some trial and error, but be patient.
Bob
herve87
Oct 26, 2013 05:12 PM
Max Macson
Apr 20, 2011 09:18 AM
saleen1276
Sep 24, 2010 11:53 PM
jscphoto
Aug 29, 2010 04:37 PM
V XII
Jun 9, 2006 09:24 PM
