1991 300se no air flow center vents
Old Jul 22, 2014 | 10:49 PM
Boni Meza's Avatar
Default 1991 300se no air flow center vents
hello all,
I have a 1991 300se that i have no air flow from center vents. i have tried a new push button control head and tested the switching valve. from what i have read on the switching valve is there in one power wire (black/red wire or black/pink), the other 7 wires to the switching valve are the grounds to each solenoid in the valve. when i add manual power to the valve and ground each solenoid i get theclicking noise. so i added vacuum to the valve and grounded each terminal and i get vacuum out of each one so im assuming the vavle is good. i thought control head was not working properly so installed a new control head and same problem. any insite into this would be greatly accepted.
fcasadon
Nov 3, 2009 08:05 AM
LoveMyE420
Jul 8, 2009 12:55 AM
tc1973
Feb 29, 2008 06:46 PM
miishmiish
Aug 30, 2007 03:20 PM
Dehaven
Apr 22, 2004 02:02 AM
