Center Heater Vents - No Air Flow
Old Jan 14, 2005 | 06:15 PM
LoveMyE420's Avatar
Default Center Heater Vents - No Air Flow
This week I noticed that there is no air flow coming out of the two center heater vents located on the front dash. The two side vents appear to work fine. The **** controlling the airflow is open to its highest setting, but no air is flowing out of these two vents when using the heater or the air conditioning.
Is there a separate fan motor or fan that needs replacement that supplies these two vents? What does this repair involve? My car is 10 years old; is this simply something that wears out over time?
Thanks!
Old Jan 14, 2005 | 09:36 PM
sleepwalker's Avatar
Default RE: Center Heater Vents - No Air Flow
no warm air?
try the lowest (cold) settings and check if there is air coming out now.
if it does, then it must be the design.
Old Jan 16, 2005 | 03:34 PM
LoveMyE420's Avatar
Hi sleepwalker...actually, no air flow at all...warm or cold. Both side vents do emit both warm and cold air.
I remember a few weeks back hearing the fan, which had developed a bit of a whine that was audible, then it disappeared (maybe that was the fan's last gasp of life :-) or warning to me). Then a couple of days ago I noticed that nothing was coming out of the center vents.
Was curious if anyone knew what the fix was for this...I guess replacing the fan or fan motor? Is it under the dash or in the engine compartment?
I love my MBZ mechanics, but am curious what I am in for as far as time and expense...
Thanks!
Old Jan 16, 2005 | 11:41 PM
either fan or microfilter which also restricts the airflow.
Old Jan 17, 2005 | 10:04 AM
Richard 300e's Avatar
I have the same problem with my 86 300. Center vents not move any air hot or cold. I went to my local MB service center and was told the following.
Center vent vacuum servo located behind the dash is the culprit.
About 6 hours labor to remove and install dash to get at this broken part.
If I had the dash removal proceedure I would do this job myself.
Does anyone have this proceedure that they can share with me?
Richard
Old Jan 17, 2005 | 10:58 AM
i have.
tell me your VIN and i'll post here.
Old Jul 5, 2009 | 09:26 PM
felinervmd's Avatar
Default vin for center air vents
Originally Posted by sleepwalker
i have.
Tell me your vin and i'll post here.
wdbab33a1cbo15327
Old Jul 8, 2009 | 12:55 AM
vytamenc's Avatar
no warm air should come out of those vents what so ever. all warm air is put in at your feet sides and winshield area. ac mode is a different story
Boni Meza
Jul 22, 2014 10:49 PM
MBZKT
Dec 31, 2010 12:01 AM
fcasadon
Nov 3, 2009 08:05 AM
tc1973
Feb 29, 2008 06:46 PM
miishmiish
Aug 30, 2007 03:20 PM
