1989 190e 2.6L Starting Problem
Old May 15, 2010 | 12:09 PM
dgreat's Avatar
Default 1989 190e 2.6L Starting Problem
Hi guys, my 190e (fuel injected) is having problems starting. First of all, I just changed the OVP Relay with a new one, well it's actually used (my original one was black with 1 fuse, this one is red with 2 fuses, just bringing this out just incase).
When the temp is 60 degrees fahrenheit or below, my car starts like half a second after I turn the ignition like literally (probably bad). in hot days I have to turn it twice then pump the gas to keep it idle, otherwise it would die.
When I'm driving it, it sputters and twitches when I apply gas on it (sometimes I can smell it burning rich). It does this for about 1 minute, then everything drives normally.
Once I start driving it though, it idles normal (between 5 to 10k RPM), but then when I put it in park it goes 20 to 25k's!
I expected the spark plugs or wires, but I just changed the rotor and rotor cap, the spark plugs looks like they are firing fine, I even gapped them right.
I just dont want to spend much money on something that has no problem ,so any help would be much appreciated...(I also havent changed anything else since 1989 besides what I mentioned)
Old Jun 4, 2010 | 06:04 PM
quantass's Avatar
dgreat, did you resolve the issue?
Old Jun 7, 2010 | 01:32 AM
dgreat's Avatar
No I havent it's not really a top Priority for my 190e but it gets annoying, especially when u are in a hurry...
oz66
Jun 24, 2013 01:18 PM
1978sac
Sep 14, 2010 11:17 AM
dgreat
Dec 8, 2009 08:08 PM
rob56
Dec 4, 2007 03:55 PM
spudsterier
Oct 4, 2006 11:24 PM
