Diesel Performance A discussion section for performance diesel modifications.
injection timing
Old Feb 12, 2011 | 03:21 PM
mikecorts's Avatar
Default injection timing
I need to adjust the timing on my fuel injection pump using the overflow spout tool. I followed the books instructions but it still ended up running the same. Would anyone be able to help me and give a good play by on how it is done correctly. Also how the drips need to be coming out, i would use the primer pump to get the fuel flowing but it would come out in a stream then slow to a drip in the same amount of time in different spots of adjustment. any help would be greatly appreciated.
Old Feb 17, 2011 | 07:29 PM
mikecorts's Avatar
So now i've tried to use the Neanderthal method, and when the valve gets a little fuel coming out it the timing marks are on the bottom side of the pulley. Does this mean its just off a decent amount or is it 180 degrees off. I feel it shouldnt be 180 off cause it was working well.
SeinBenz
Dec 1, 2013 02:36 PM
Junger
Mar 20, 2013 05:38 PM
marwan26
Sep 1, 2009 07:33 AM
mercedesnut
Nov 6, 2006 05:58 PM
mpetrilla
Sep 10, 2005 10:12 PM
