Does 1996 C220 have timing belt or timing chain?
Old Apr 14, 2004 | 12:13 AM
Junger's Avatar
Default Does 1996 C220 have timing belt or timing chain?
Thanks,
Rick
Old Apr 15, 2004 | 02:52 AM
sleepwalker's Avatar
Default RE: Does 1996 C220 have timing belt or timing chain?
after some years with mercedes-benz dealership, i've never heard of timing belt Junger.
your's is using timing chain.
Old Apr 17, 2004 | 11:55 PM
Junger's Avatar
Thanks... Will the timing chain last as long as the life of the engine or does it require replacement?
Old Apr 18, 2004 | 12:02 AM
the timing chain also need to be replaced for it is elongated after a certain period of time.
this elongation could affect the timing gears (camshaft) and sharpen the cogs (teeth).
any deviation on the timing of about plus or minus 10 degrees calls for a replacement, or else you have to do it every 100,000 kilometers.
it is an easy job which takes 2 hours with the right special tools and trained mechanic.
Old Mar 20, 2013 | 05:38 PM
alanskip's Avatar
Default 1996 merc c200 timming belt ( chain)
96 has a timming chain but when we replace it with a new 1 it was 1 link to short donot know why ?
we had 2 new chain to check size both are 1 link to short ?
any way we place 1 more link in it now seems ok but very hard to doo
any1 can tell us wert we can check it or how to do it right details
we also replace water pump as it started to leak also repllace all hose
s500jamie
Jun 30, 2019 03:03 PM
rgrayoh
Mar 11, 2010 08:57 PM
hillbilly2
Nov 28, 2008 07:31 PM
Slkboi2000
Sep 5, 2006 07:01 AM
ML4300
Jun 18, 2005 01:04 AM
