turbo
Old Oct 19, 2005 | 01:37 PM
aztom's Avatar
Default turbo
have a 87 300SDL and there is a very small cut / opening in the exhaust housing next to the turbo. Is this something that can be fixed, also oil residue is on the turbo.
Old Oct 21, 2005 | 09:29 PM
Benzbob's Avatar
Default RE: turbo
It is kinda hard to know exactly where this cut, or whatever it is you see, without posting pictures!
If the cast iron manifold is cracked, you may be better off replacing it. Turbo's will weep a tiny bit of oil in these 603 engines and that is not a bad thing, or unusual. If it is constantly dripping oil and you have to add oil frequently as a result, then there is an issue with seals, or even a loose oil supply tube.
geoff.doctor
Jul 12, 2008 10:54 AM
jthawk71
May 20, 2008 07:47 PM
joshbaker
May 25, 2007 10:51 PM
Nosedive
Jul 4, 2006 01:41 AM
mrhappy
Jan 31, 2006 10:51 PM
