squeeling sound at rpm
Old Jan 31, 2005 | 05:18 PM
painter527's Avatar
Default squeeling sound at rpm
I need help, my 300D starts squeeling when i give it gas. It sounds like it is coming from the belt area directly behind the radiator but i don't see any change in the belts as it starts to squeel, my buddy thinks it might be bearings but it only happens when the rpms go up. It started a few weeks ago but it seems to be getting worse. Has anyone else had this problem, any ideas?
Old Jan 31, 2005 | 05:30 PM
pberku's Avatar
Default RE: squeeling sound at rpm
A quick test to confirm if its a belt or not is to squirt a bit of water, (or WD30) directly on the belt while the engine is running and see if the noise diminishes. If it does than its the belt, if not than you need to look elsewhere.
Phil
Old Feb 21, 2005 | 02:02 PM
rcgiddings's Avatar
WD-30???????????
Old Feb 21, 2005 | 03:54 PM
pberku's Avatar
Hay, I am Canadian, so WD-30 CDN, is equivalent to WD-40 US.
There you go!
Phil
Old Feb 21, 2005 | 09:21 PM
rcgiddings's Avatar
You'll have to excuse me; I grossly underestimated the effects of deflation re: merchandising. I should have been aware of the domino effect, or is it "affect"(!) and scheduled my next flight on a DC-2 1/2! I'm sorry I called it to your attention; it must be very painful....
Old Feb 21, 2005 | 09:26 PM
rcgiddings's Avatar
painter 527,
Surely, by now, you have learned that it's a belt! It got worse, or the belt broke, and then it was obvious? Did you know that WD-40 is also good for fire-ant bites? It takes the sting out of them. It's not just for breakfast anymore!
mb85diesel
Aug 12, 2008 08:40 AM
widmer
Oct 3, 2007 06:42 PM
grish
Jun 21, 2005 10:38 PM
bjohnson
Jan 21, 2004 12:51 AM
cmscott16
Jan 3, 2004 06:50 PM
