LOW POWER ISSUE
Old Nov 12, 2008 | 07:07 PM
EVILWEELEE's Avatar
Default LOW POWER ISSUE
HI EVERYBODY, IVE GOT A 1977 300D, THE ENGINE RUNS GOOD BUT DOESNT HAVE GOOD LOW END POWER. FUEL FILTER HAS BEEN CHANGED, IM LOOKING FOR FUEL PSI SPECS AND WHERE TO TEST AT? ANY KNOWN ISSUES TO LOOK FOR PLEASE LET ME KNOW. THANKS
Old Nov 13, 2008 | 07:49 PM
EVILWEELEE's Avatar
Default RE: LOW POWER ISSUE
AS FAR AS I KNOW THE VALVES HAVE NEVER BEEN ADJUSTED, THE CAR SAT FOR 12YRS., I CHANGED THE FILTERS AND DID SOME MINOR MAINTANCE TO GET IT RUNNING. IT RUNS GOOD BUT JUST DOESNT SEEM TO HAVE THE LOW END POWER. I TAKE IT THAT THEY USE SOLID LIFTERS? IS THIS A KNOWN ISSUE TO START OFF W/ DIAG.? WHO KNOWS THE DIESEL THAT WAS IN THE PUMP AND NOZZLES COULD STILL HAVE THAT VARNISH BUILD UP. IVE TRYED USING SOME DIESEL CONDITIONER, AND IT HASNT SEEMED TO WORK.
Old Nov 14, 2008 | 07:21 AM
cycleboy's Avatar
Adjust the valves and do compression and leakdown tests. Unless the car was properly stored you've probably got indentations on the cylinder walls where the piston rings rusted against them and those are quickly wearing away your rings and eroding your compression.
Old Nov 14, 2008 | 07:22 PM
EVILWEELEE's Avatar
THANKS, I GUESS ILL START WITH THE VALVE ADJ. AND GO FROM THERE.
talha1210
Dec 23, 2024 09:38 PM
MercedesFanat1c
Mar 7, 2008 07:34 AM
honda285
Feb 8, 2008 09:27 PM
mpelchen
Oct 26, 2007 08:20 PM
mpelchen
Oct 13, 2007 08:42 PM
