How to spot bad Fuses?
Old Sep 28, 2010 | 10:24 PM
lindajane's Avatar
Default How to spot bad Fuses?
My blinkers went out, along with windows and gas gauge.
Before I do anything more (If I can). I want to check my fuses.
My car is an 83 diesel w123. On one of the fuses I noticed that the steel/metal piece running from top to bottom on one side, It was bent up.
How can I tell if the other fuses need replacing.
LJ
Old Sep 29, 2010 | 06:57 PM
benzguy's Avatar
Hi there.
I think the first investment (small) should be a voltmeter,practical they are.
Like I have posted in a previous thread,a small hair line crack is enough to not make contact.Please be sure to replace your defectives fuses with a porcelain type fuse.
Cheers
Old Sep 29, 2010 | 08:24 PM
Diesel9112's Avatar
Get the Voltmeter any way. If you are in the USA Harbor Freight sells Digital Volt/Ohm Meters (Multimeters) for less than $5.
Look at your the Fuse Chart if you have one in the lid of the Fuse Box. If it was me I would pull them and check the tips and were they make contact.
The one pictured below looked good but when I pulled it look at the suprise I found.
Get rid of any Plastic Bodied Fuses and replace them with Ceramic Bodied Fuses. Also, ones with Copper or Brass strips corrode less than the White Metal ones do.
kopy kat
Jan 2, 2008 11:36 PM
Sean
May 10, 2006 07:31 PM
Sean
May 8, 2006 09:27 AM
oink
Nov 23, 2005 03:29 PM
theps2source
Jan 11, 2004 09:36 PM
