oil spot on floor
Old Jan 2, 2008 | 11:56 AM
kopy kat's Avatar
Default oil spot on floor
found a 6 x 3 inch oil spot under my '03 SLK230 today---appears to be motor oil--sitting approximately under the intake air filter box area (passenger side-inboard of the FR wheel).
any ideas as to what might be in that area that could be leaking?
TIA--Larry
Old Jan 2, 2008 | 12:08 PM
desmoduc's Avatar
Default RE: oil spot on floor
sounds like mine ... though I have determine mine is from the tranny based on smell of the oil and a closer inspection from underneath.
- Andrew
04 SLK 320
Old Jan 2, 2008 | 12:53 PM
kopy kat's Avatar
not tranny--too far forward and typical motor oil smell and look.....
Old Jan 2, 2008 | 11:36 PM
buellwinkle's Avatar
I had the same problem and dealer told me I needed to spend $3,455 changing head gaskets and shocks and brakes front and back, told them not this sucker, not today. It turned out to be that it was leaking by the oil pan bolt, took it to an independent, he removed it, put a new washer, and it's been fine for 9K miles now. It's hard to tell where it's really leaking from because thebelly pan will carry the oil and dump it where it wants. So whatI did is remove the belly pan, spray degreaser underneath and wiped everything downand putcardboard underneath and foundwhere the oilwas dripping from.
benhagon
Jan 5, 2009 01:37 AM
Sean
May 10, 2006 07:31 PM
Sean
May 8, 2006 09:27 AM
oink
Nov 23, 2005 03:29 PM
theps2source
Jan 11, 2004 09:36 PM
