Help with purge
Old 01-24-2014 | 07:01 PM
greythunder's Avatar
Default Help with purge
Hi everyone! my first post here, somewhere i never thought i would be lucky enough to be a member of. Just bought a 300d 2.5 with 127K. I need to do a purge bc of smoke rough idle etc. I think i have gotten down how to perform the purge using a bottle with the pressure and return lines pulled and put into the bottle. Everything I'm reading online points to using a hand primer pump to pull the air out of the hose before you start.
Does the om602 have a hand primer?
Old 01-25-2014 | 10:35 AM
thanks for the response. I'm relatively new to diesels, so help me understand please. are you saying purge is bad for my particular injection pump, or all of them? I ask because this is the first I've heard of a purge being bad. I checked around the charlotte metro area, and the best i can find is b20.
Old 01-25-2014 | 12:30 PM
oldrebuiltdodge's Avatar
Additives are generally a waste of money. Some of them can cause damage because the ingredients remove lubricating qualities from the fuel, something very necessary in a high pressure pump such as an injector pump. The people who sell them will never tell you that they might hurt anything. Having said all of that an anti-gelling additive during a sudden cold snap is probably a good idea.
Old 01-25-2014 | 08:03 PM
so not being well informed, i did the purge anyway... and while doing it the idle smoothed out and was WAY more quiet. granted, it's cold as hell here. however, within 5 minutes of reconnecting the pressure and return lines the "loudness" was back. I failed to mention in my first post that the car sat for about 7 years in a garage and was driven intermittently to have service done at the dealer. all the hoses, filters, etc are mb genuine parts. where do i go from here?
Its_Puddin!
08-04-2011 06:34 PM
jodyhb
07-03-2011 10:05 AM
tygman
05-20-2008 07:15 PM
81 300 CD
12-02-2006 10:34 PM
