Glowplug Relay strip fuse broken
Old Dec 9, 2005 | 04:58 PM
lldanj's Avatar
Default Glowplug Relay strip fuse broken
I have a 1984 3300D and the GP light stopped coming on. I opened the GP relay box and the fuse strip is broken (melted actually). I had just tried to start the car and there was a burnt smell coming from the fuse strip. I have read other threads here and want to see if this is how I should proceed.
1 - Use a multimeter to test each GP from the harness in the relay box.
2 - replace bad GPs
3 - replace the fuse strip
Is that right, or is there something else? What causes the fuse strip to break? I just got an oil change two days ago. is it possible that some oil got onto a GP wire and shorted it out?
Thanks so much!
Dan Rosenberg
www.vegcar.net
Old Dec 9, 2005 | 11:08 PM
Benzbob's Avatar
Default RE: Glowplug Relay strip fuse broken
Oil will not short electricals!
I would proceed with your 3 steps.........Ohms should be somewhere around 0.3 to 0.8 usually for GP's. Digit hunting indicates a dead GP. GP relays can go bad too!
n4wsu
Aug 15, 2012 06:51 PM
wcmartin75
Jul 10, 2010 04:07 PM
wcmartin75
Jul 8, 2010 02:19 PM
mmmcheechy
Oct 7, 2009 11:13 PM
ivanw
Aug 19, 2004 10:21 PM
