glow plugs fuse burning frequently
Old Apr 8, 2006 | 01:29 AM
cyberdoc's Avatar
Default glow plugs fuse burning frequently
[size=3]I have a 300D engine working on an original 123 who had a 240D euro version. It was necessary to make all the electric circuits to change the original starting system of that 240 engine to the actual motor that cranks and stop by using a key. It runs great, but recently is burning the strip 50amp fuse, melting also the plastic fuse box. We made a new instalation attending to clean and tight all conections, but we din't fix the problem. It still burning the fuse after a few crankings. The engine uses a loop glow plugs type that I understand are serial connected so that a fault of one of them (in case of shorten internally) not allows to start the engine. That could be the reason of the problem and possible solution? Thanks in advance, Luis.
jeffb
Jan 2, 2009 08:33 PM
ak
Jan 31, 2007 11:53 AM
teepolo
Sep 17, 2005 11:15 AM
teepolo
Jul 28, 2005 06:47 PM
Kichus
Feb 9, 2004 06:31 PM
