timing chain, glows, valves what else?
Old Mar 16, 2006 | 01:34 PM
hooligan's Avatar
Default timing chain, glows, valves what else?
About a month ago I bought an 83 300SD. No idea as to the history of it. It's got about 120k on the non-working odo.
I have a new timing chain on order and will be doing that along with adjusting the valves, replacing the glow plugs, air filter, oil filter, new oil, and diesel purge with new filters.
What else would be recommended to try to put this car back on track as a properly maintained MB?
Old Mar 17, 2006 | 11:07 AM
vstech's Avatar
Default RE: timing chain, glows, valves what else?
look over at dieselgiant.com amazing free info of stuff. they reccomend changing the dif oil, and show you how to do it. and purging the injectors and again show you how to do it. really amazing site.
Old Mar 18, 2006 | 05:41 AM
Oldpete's Avatar
Hi vstech would like to say thanks for the link to dieselgiant.com. Most helpful
Old Apr 10, 2006 | 11:48 PM
drujinin's Avatar
Changing the mentioned parts will get the engine started back on track along with the rear end, but what about the coolant/radiator flush and change? Then if its an automatic transmission what about its filter and fluid? That goes for a standard transmission and clutch check/adjust. Then of course there are brakes lines to inspect, stuck brake calipers (rears) and a fluid flush too. Changing the power steering filter/fluid? Belts and check alternator bearings for noise with the belts off?
The list grows, do you want more to keep you busy?
Jeff
Junger
Mar 20, 2013 05:38 PM
Slkboi2000
Sep 5, 2006 07:01 AM
PANSSER
Dec 27, 2004 01:26 AM
Mwagon
Jun 4, 2004 10:33 PM
T Lindau
Dec 29, 2003 03:10 PM
