Flap in the air intake???
Old May 13, 2010 | 05:39 PM
tcris3's Avatar
Default Flap in the air intake???
Hi, I was just wondering what the flap is in the air intake as it is completely closed and I would imagine blocking air flow. also is there a MAF in there? it looks like it but I didnt think diesels have MAFs. Thanks for the info -Cris
Old May 14, 2010 | 08:19 AM
tcris3's Avatar
Thanks. The entire unit can be removed without any issues? no check engine light?
Old May 14, 2010 | 09:45 PM
tcris3's Avatar
its a 1987 300TD wagon 246k
Old May 15, 2010 | 05:35 PM
jlguler's Avatar
Originally Posted by ForcedInduction
Yes. Removing it will have no negative effects. Your vehicle has no form of check engine light.
Can I remove the one on my 300SDL?
John
Old May 16, 2010 | 11:04 AM
jlguler's Avatar
Anything up to 1991. 91-95 the turbo is controlled by the computer and a normal wategate will need to be used. 96+ the engine is completely electronic and the EGR code will have to be deprogrammed out of the ECM.
Thanks,
Mines a 1987, so I think i'll remove it. I'm sure it is restrictive at the least, and I've already blocked off the EGR anyway.
John
Old May 16, 2010 | 09:41 PM
sundaynsonz's Avatar
Default Removing EGR
Can you walk me through in removing or blocking the EGR in my 96 E300 and how is it
deprogrammed? thanks ForcedInduction.
Old May 21, 2010 | 12:05 AM
Thanks ForcedInduction...will try this method and will give you feeback.
Old Jun 11, 2010 | 07:33 AM
narshdrew's Avatar
any feedbacks? im quite interested on how this turns out.. will it not have any long term effect on the air intake?
naomi
Oct 1, 2007 10:04 PM
mattc230
Aug 18, 2006 05:27 PM
mambodave
Jul 7, 2006 11:12 AM
MINDBENDERO
Sep 16, 2005 09:31 PM
Arn560
Aug 22, 2005 12:15 AM
