Antenna not going up
Old Feb 27, 2007 | 01:00 AM
Mr.47's Avatar
Default Antenna not going up
My antenna goes down but not up, it goes up when the radio is on, (about 1/4 up)and it won't budge,
any suggestion to fix it?????
Thx
Old Mar 13, 2007 | 12:05 PM
AMGMercedes's Avatar
Default RE: Antenna not going up
It's probably jammed. Pull out the antenna device inside the trunk and take a peak inside it when the antenna's up. Unplugged ofcourse.
Old Mar 14, 2007 | 03:04 AM
Its_Puddin!'s Avatar
I know when its really cold it almost freezes in its place. When mine gets stuck, I push the antenna button up and leave it on and then manually pull it up slowly. It does catch and get back going. Has worked for me.
Old Mar 14, 2007 | 12:25 PM
Drrty240D's Avatar
I give my antenna alube every year to keep things working smoothly. Wrap an old rag around the base of the antenna so you don't drip on your paint.Finda piece of old sponge, soak it withWD-40 and work the lubricant down into the mast sections that are visible. Run the antenna up and down a few times and you should see some definite improvement as the lube works it's way in.
The WD-40 will free up some old grease and grimeas the antenna begins moving again, so keep wiping the mast clean with a rag or paper towel until you haveclean lube with no dirt in the joints.
Old Mar 14, 2007 | 01:16 PM
Mercedes Benz of FL's Avatar
Acetone clean your Antenna poles
Then use WD-40, Light Oil, Gun Oil to lube up the poles
and then have Antenna go up and down to lube the pole.
That should get it unstuck and moving freely
Good Luck!
JimMayor007
Sep 21, 2008 01:27 AM
chicagoc320wagon
Jul 29, 2008 10:13 AM
cjsmith79
Nov 21, 2007 02:27 PM
JeremyJamesDec15
Jun 1, 2007 05:12 PM
kazooguy
Sep 28, 2005 10:30 PM
