96 300 d power issues
Old Jul 5, 2009 | 09:57 AM
feam's Avatar
Default 96 300 d power issues
Have 96 300 d with power issues when warm , when cold its fine . good pickup. when wram after 45 minutes of driving , from standstill it has no power, just creeps till it gets momentum. all filters fuel and trans new , im thinking fuel pump , or IP cant test fuel pump on this car, does this fuel pump get tired when warm. Any ideas , Thanks
Old Jul 5, 2009 | 11:01 AM
feam's Avatar
Default IP or fuel pump
A better question to help me diagnose my problem , seems to be fuel related. Does the fule pump get tired? Will it perform fine when cold and lower psi when warm? Same question for IP? or does Ip just fail?
thanks.
Old Jul 12, 2009 | 08:02 AM
pimpernell's Avatar
thanks.
I drive the same year car, and I would suggest checking both fuel filters as a start to insure that they are seated properly, and that the O ring in the pre-filter is properly in place. The only time I encountered this type of issue was this past winter. Temperature was down around 20 degrees, and on my last fillup, the amount of anti-gel I had on hand was not sufficient for the amount of fuel I added. The next morning, when I first started out, the car would only reach 40 mph, and it was very sluggish. After about 5 minutes of driving, that condition cleared up. The other issue could be algea buildup in the fuel tank. I use Startron on a regular basis, and have not had any issues in that area. If it is algea, even if you change out the fuel filters, it will clog them up in short order if not treated. Hope this helps....
Old Jul 13, 2009 | 11:37 AM
Fight On's Avatar
Since the algae issue was brought up, how would one fix an algae issue ? Is this a common problem for diesels ? Does it only affect fuel tanks, or the fuel lines also ?
Thanks.
Old Jul 13, 2009 | 12:38 PM
cycleboy's Avatar
There's an additive you buy at most any auto parts store that will kill whatever algae is in there. You will have to do a couple filter changes as the dead organisms get flushed through the system.
Oldskoolbenzo
Jun 12, 2014 01:07 PM
leemegg99
Mar 5, 2013 12:53 AM
risd130
Feb 29, 2012 02:21 PM
disbo
Aug 18, 2007 09:39 AM
1990300SELMAN
Feb 8, 2005 10:20 PM
