87 TDT problem
Old May 20, 2011 | 07:11 PM
hooverfull's Avatar
Default 87 TDT problem
I'm having a strange problem with my 87 300 TDT. It seems during acceleration, when the tach hits around 3500 or so, the engine cuts off power but quickly regains it. It isn't a sputter, but as if fuel has been cut off. I changed both filters twice, and have had the tank screen replaced within the last 1000 miles. I did notice the valve cover vent was spewing out, and the hose was completely off spewing oil all over the place.
Could this be related to a loss of power, something to do with pressurizing the crank case?
Also, the air filter is clean.
Any help is appreciated.
Old May 23, 2011 | 11:56 AM
hooverfull's Avatar
very interesting, got the new blowby assembly and installed it. Fixed the problem. Didn't know that would affect the way the car runs so dramatically.
Old May 26, 2011 | 10:37 AM
wkhall's Avatar
I have the same problem. What is a "blowby assembly", where does it mount, how much was it, and where did you get it? Thanks!
Old May 27, 2011 | 01:47 PM
hooverfull's Avatar
It's also called the valve cover breather assembly. Pressure from the engine is released through this hose and some oil will come through the assembly. It is probably a dealer part. Probably around 100$ or so. The gasket plug that goes into the valve cover usually becomes brittle, so take care when removing it. The breather assembly has a plug that goes into the gasket plug and leads to the air cleaner under the filter. Obviously, don't let plastic or rubber bits go into the valve cover.
Old May 28, 2011 | 09:53 AM
wkhall's Avatar
I just took a look at my car. The only thing coming out of the valve cover is black rubber hose about 14 ~18 inches long, kinda like a PCV hose. IS that all there is to it, just the hose?
Does it look like this:
http://www.autopartswarehouse.com/se...Breather+Hose)
Preben
Aug 10, 2013 09:01 AM
Horace Thompson
Jan 11, 2011 09:40 AM
rover1
Oct 28, 2009 08:42 AM
rowdyreda
Feb 2, 2009 01:00 PM
pepstdt
Mar 23, 2008 05:25 AM
