87 300D ... abs? brake noise?...
Hard to describe noise past three weeks. This is an 87 300D which is an occasional driver. New brakes about 8 months ago, perhaps 2000 miles on those.
Noise is a groan or scraping noise from left front. Most frequently at parking speeds with wheel turned to left. Has also happened in reverse both during braking and for a moment after stopping while backing down a steep driveway. This noise is hard to describe. It sounds like scraping, but not a metal on metal squeal sound. No warning lights or signs of difficulty braking. Any Ideas? Thanks
Try using some brake grease on the edges of the pads, but not directly on the rotor or pad's braking area. It should tell you on the little grease packet.I had the same thing happen with day old pads b/c it didn't get greased, butthe sharp noisewent away after a week.
The noise isnot a squeal nor gringing...its like a RRRfff noise like 2 card boardscraching together, before it was only when turning to the left,now I get the noise even when driving strait..Any ideas????Thanks
sladedestiny
Aug 3, 2012 02:55 PM
stevey88
Mar 18, 2007 05:19 PM
