85 300SD Block Heater - help
Old 10-20-2005 | 02:10 PM
timberfield's Avatar
Default 85 300SD Block Heater - help
I previously kept my 300SD in the garage during the winter, but this year it's going to live outside. I thought I would locate the plug for the block heater and setup a timer ect. Guess what.....no plug! I thougt there was one, but I must have been thinking of my 81 SD.
Are block heaters standard equiptment? Is there a heater built into the block, or should I buy an aftermarket one? Any idea where it would be located or where to buy??
Many thanks!!
Old 10-20-2005 | 02:19 PM
Kajtek1's Avatar
Default RE: 85 300SD Block Heater - help
Never had to use block heater in CA, but remember plugs in the front of the radiators. When they are not used, than sometimes mechanics kicks the cable down.
If you don't find original heater, than I've seen heaters with magnets, that you stick to the oil pan at JC Whitney.
Old 10-20-2005 | 02:46 PM
That's some help, thanks!
There is definetly no plug there now. I was hopeing to find where the OEM heater is located and see if I have one on my car.
mercedes86
10-16-2009 06:25 PM
joemal
09-04-2007 06:20 PM
rcssafety
08-13-2005 05:26 PM
FogHorn
09-08-2004 10:04 AM
Kichus
01-28-2004 09:13 PM
Quick Reply: 85 300SD Block Heater - help
