84 300d gauges
Old Aug 6, 2018 | 01:23 AM
Clanky's Avatar
Default 84 300d gauges
just brought a 84 300d and the fuel gauge and temp gauge read higher and fuller in relationship to each other the faster I go and the longer I drive. They also bounce around a lot. Car shows no sign of overheating but the gauge is way wonky
Old Aug 6, 2018 | 03:13 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! That could be a sensor malfunction. Have you checked them?
Old Aug 6, 2018 | 07:38 PM
Clanky's Avatar
Bothbthe coolant gauge and fuel gauge rise and bounce together and seem to get hogher the faster I go
Old Aug 11, 2018 | 01:15 AM
Clanky's Avatar
Default Bump
Anyone have any ideas
Old Sep 2, 2018 | 11:23 PM
Bundye's Avatar
Default Try running a new ground from the gauges
My 240 was doing the same thing. I attached a ground wire on each of the two screws that stick out of the back of the instrument panel from the temp and fuel gauge and attached the other ends to the cluster of other wires grounded on a screw behind the dash. Completely solved the issue. Let me know if you need a better description. I can also provide some pictures if that helps.
Al
Old Sep 3, 2018 | 01:38 AM
Clanky's Avatar
Default Gauges
I’ll try that this week. Thank you. I hate not having gauges
Bergermiester
Apr 6, 2016 09:54 PM
GolfMBenz
Jun 1, 2008 05:14 PM
jimkari
Feb 2, 2007 11:02 PM
nmunif
Mar 4, 2004 03:03 PM
