2007 E320 Repeated gold coil warning with CEL after glow plugs replaced
Old Jun 15, 2011 | 10:18 PM
lypdmd's Avatar
Default 2007 E320 Repeated gold coil warning with CEL after glow plugs replaced
MY 2007 E320 Bluetec, 69000 miles. Original owner. The gold coil warning sign came on intermittently and eventually the check engine light came on constantly 1 month ago. I found that the glow plug #2 was bad from reading the OBDII scanner.
I ordered all new 6 OEM glow plugs from MB and replaced them myself. Planning to keep the car for another 6 years. Kept the older 5 plugs for later use if needed.
Check engine light still stays on after 3 weeks of driving. The gold coil lights up on start up for 20 seconds in the morning and leaving work. I try to clear the CEL with the OBD scanner but it comes on the next day. The scanner reads glow plug #2 can't communicate.
The car drives fine. No hesitation, no smoke from tailpipe, mileage seems the same on 1 full tank as before.
What could I have missed?? Is there something else I need to replace?? Should I disconnect the battery to reset the CEL?? Researching the internet, is there carbon build-up in the original failed glow plugs chamber that I need to clean with a brush?? Do I need a SDS reset instead??
Thanks in advance
Pat
Old May 23, 2024 | 07:00 AM
malkos's Avatar
I gave my mother a gold chain for Mother's Day, because jewelry is not only a gift that stays for a long time with a person, so it is also a gift that does not lose much in value, and always remains valuable, and gold jewelry over time can only and grow, you can see for yourself on poshmark canada what prices for old jewelry, some unique jewelry in the price has increased in value several times, and some cost cosmic money because of their rarity.
NM76
Jan 7, 2012 10:38 AM
Rogmerc
Feb 20, 2011 02:49 PM
3Ray
Sep 4, 2010 01:52 PM
thirstyvalves
May 29, 2010 11:26 AM
AMGMercedes
Jan 10, 2008 09:41 AM
