1996 300D won't start
My diesel will not start after I had probably lost some glow plugs (rough starting and running after starting) Is it possible I lost all plugs or does the computer? lock out the fuel after so many plugs don't work?
Also it looks like a lot of parts have to be removed to get to the plugs?
Best place to get plugs reasonable priced.
Can somebody help? Thanks
Thank you pimpernell?,
It is not too cold, 18C. I was aware that some plug must be bad, i.e. sign stays up.
But this time is different. 5 minutes after I started it it would not start again, feels like no fuel.
Good pointer about the problems with removing the plugs, thank you.
For starters I will replace all plugs, that's how the problem started.
I found a place, Auto Parts Warehouse, Bosh plugs $~20.00. that sounds good.
Goldengirl1
Nov 8, 2012 07:28 PM
