1996 300D won't start
My diesel will not start after I had probably lost some glow plugs (rough starting and running after starting) Is it possible I lost all plugs or does the computer? lock out the fuel after so many plugs don't work?
Also it looks like a lot of parts have to be removed to get to the plugs? Best place to get plugs reasonable priced. Can somebody help? Thanks |
Originally Posted by axel_g
(Post 151487)
Thank you pimpernell?,
It is not too cold, 18C. I was aware that some plug must be bad, i.e. sign stays up. But this time is different. 5 minutes after I started it it would not start again, feels like no fuel. Good pointer about the problems with removing the plugs, thank you. For starters I will replace all plugs, that's how the problem started. I found a place, Auto Parts Warehouse, Bosh plugs $~20.00. that sounds good. |
(Post 151535)
