1993 E300D Transmission Problems
Old Apr 12, 2013 | 01:32 AM
jojohn2008's Avatar
Default 1993 E300D Transmission Problems
Im having a problem with my transmission when the transmission is cold it shifts really fine.
after its warm and I start driving again it slams hard into the next gear.
my commute is 20 miles. where I work is seconds from the highway. I will do 70 miles an hour for 19 miles with no problem. when I get off the highway from a dead stop at the light it will shift hard it will high idle then slam into the next gear
can someone enlighten me on what could be the problem?
if it helps any after I did the brakes on the car that's when the problem started. I can answer back very quickly as the notification email goes to my phone
Old Aug 10, 2013 | 09:10 AM
MB_ML270's Avatar
Default 124 transmission
Any slipage or hesitation going into reverse is a sign of a bad transmission. Also the front and back ends of the drive shaft have a rubberized flexible drive couple that is a maintenance item. Having one of these fail is a very bad thing. Probably around a 200km-250km lifespan on transmissions, depending on a lot of things.
hd wood
Jun 29, 2010 09:45 PM
mpgagnon
May 25, 2010 03:00 PM
blocke
Nov 14, 2008 05:27 PM
Mr.Billyd
Aug 7, 2007 04:10 PM
calico259
Mar 8, 2006 12:12 PM
