1982 300D won't start
Old Jan 25, 2009 | 03:33 PM
lb2281's Avatar
Unhappy 1982 300D won't start
I have a 1982 300d that won't start. Whenever I try starting the car initially it turns over as if it will start then dies. I checked to see if my son had put gasoline instead of diesel in it (he did that last year) that seems ok. What else can I possibly check, for past week it had been taking many attempts to turnover before it started. Also glow plug light had stopped working since last year.
Old Jan 25, 2009 | 04:22 PM
1sloturtle's Avatar
there are possibly 2 things first is the glow plugs might ont be working causing a hard start check to see the amp draw best if you have a dc amp clamp around glow plug wireharness set to highet setting should read 3+ amps or so. also check the glow plug relay box located just behind the driverside headlight it should be a box (black or metal box with 2 seperate wire connectors plugging into it . that supplies power to glow plugs also controls your dash glow plug light . its either a burned out bulb in kombi or glow plug relay module is bad . i would start there . also shine a light behimg the fuel filter the fuel should be clear with no particales . or dark sections in it
some times the fuel ca be contaminated if sitting a while causing hard/no start
jimishadow's Avatar
Thumbs up glow plugs
diesel giant has a glow plug repair article.chec it out www.dieselgiant.com/glowplugrepair.htm
Old Feb 5, 2009 | 11:25 PM
lb2281's Avatar
Changed glow plugs and car starts, thanks for the sugeestions they were great
Glow plug light now works too.
spoiled_amy
Sep 12, 2024 11:45 AM
Goldengirl1
Nov 8, 2012 07:28 PM
angelbay
Apr 27, 2012 08:54 PM
doobs
Dec 21, 2008 09:58 AM
johnnyraynes
Feb 6, 2007 10:32 PM
