1978 300d glow plug relay fuse blows when I turn ignition
Old Jun 3, 2009 | 01:00 PM
Cantukeeslim's Avatar
Default 1978 300d glow plug relay fuse blows when I turn ignition
The glow plug relay fuse blows within a few seconds of turning the ignition to light glow plugs. Does anyone know what might cause this?
I just replaced the starter myself. Could something I did cause while replacing the starter cause the glow plug relay fuse to keep blowing?
Do I just have a bad glow plug or two?
thanks.
Old Jun 3, 2009 | 03:20 PM
cycleboy's Avatar
If it worked before you worked on it, and it doesn't work now, I would go back and check your work. The fuse blows because there is too much of a load on it, either because of a short or whatever is fused is pulling too much electricity. Perhaps you pinched a wire or didn't connect one properly.
Old Jun 4, 2009 | 01:06 PM
Thanks, cycleboy.
I'll go through and check all the cables and wire connections.
MBJunior
Apr 12, 2011 03:42 AM
wcmartin75
Jul 10, 2010 04:07 PM
wcmartin75
Jul 8, 2010 02:19 PM
BStiles
Mar 11, 2009 02:05 PM
jeffpflueger
Feb 25, 2008 09:39 AM
