1976 240D W115 Issues
Old Dec 8, 2011 | 11:32 AM
B.Reilly01's Avatar
Default 1976 240D W115 Issues
So I recently purchased the above mentioned car, and I need a little help with a few things... Probably the most pressing problem is that the mount for the steering idler broke off. This happened either while I was removing the tires or towing it home, either way, is there a way to fix this short of welding it back in place and hoping it's aligned/can be aligned? I'll try to get pics when I get home.
Also, I went to pull the radiator, and the transmission cooler fitting in the rad broke. Now I can spin and spin the fitting and it never comes loose. If I cut the hose, will I be able to use a barb and clamps to hold it together?
The oil cooler leaks, and I'm having a bear of a time bleeding the brakes...
The primer pump leaks as well, I picked up a new style one, but how do I remove the old one?
Thank you in advance
Doomsdaymen
Apr 15, 2011 01:32 PM
bugly64
Mar 22, 2011 12:36 PM
bryanworldwide
Dec 15, 2010 09:21 PM
yourcandlegrrl
May 26, 2010 07:12 PM
TimWheeler
Apr 19, 2009 06:14 PM
