ml 320 limp home mode?
Old 01-20-2007, 09:23 AM
greekpilot767's Avatar
Default ml 320 limp home mode?
Hello all,
Please help!! i got a ml320 that just will not move. new fuel pump and filter blah blah blah. Is there something i am missing? It had ets/abs light on and mechanic (very trusted and old school MB guy) found something ate through front right abs sensor wire. Fixed that all lights went out still wont accelerate?!?!?! he even tried a new ecu with no luck.
Thanks,
Alex
Old 01-20-2007, 03:13 PM
AMGMercedes's Avatar
Default RE: ml 320 limp home mode?
Time to get a new school MB guy then. The problem could be a number of things and what I find interesting is that a lot of these mechanics have no idea how to fix limp-mode problems. They throw parts at it until the problem is fixed before addressing a cause.
Old 03-17-2007, 02:34 PM
This may be transmission problem.Limp home mode is when trany lock in 2-nd gear allow you to drove home or car shop.You can't accelerate, just slowly ,,limp" back home for short distance.I suspect electronic sending unit failure. But it may be just low level transmission fluid or so.Find someone with code reader to check computer fault codes.
WojtekSki 2001 ML 320 ( wife)
andrewandlorraine
03-11-2024 06:00 PM
tmirza
06-28-2009 11:04 AM
bbrreid
01-06-2008 08:03 AM
d4vey
12-21-2005 07:42 AM
addys
06-23-2005 12:09 AM
Quick Reply: ml 320 limp home mode?
